I have a cnPilot e400 device that i'm deploying in the Bahamas. I have the TX set to 'default' but i am unable to sync my config down to the access point. Every time I try, I get the error: "Power Level Not Supported"
I haven't worked a ton with these devices, so any assistance would be appriciated.
could you please confirm the AP is running the latest firmware release (3.11.2). If so,it would flag the tx power change (if set to max, the AP will automatically lower it to whatever regulatory allows), and just report a warning not an error that blocks config-sync.
