jiunnyik
(jiunnyik)
#1
Does anyone know what is the actual hardware spec for cnPilot e400?
I would like to know what is the data rate supported by e400.
Below is example data rate supported by Asus Lyra.
802.11a : 6,9,12,18,24,36,48,54 Mbps
802.11b : 1, 2, 5.5, 11 Mbps
802.11g : 6,9,12,18,24,36,48,54 Mbps
802.11n : up to 400 Mbps
802.11ac : up to 867 Mbps
Thank you.
firefly
(firefly (inactive))
#2
@jiunnyik wrote:
Thank you.
on 802.11n the e400 supports up to 300Mbps, otherwise the data rates in various modes are the same as the Asus Lyra.
The Asus Lyra is tr-band (has 2 5GHz radios), and the 5GHz radio is wave2 with MU-MIMO (like the 5GHz radio on the cnPilot e410).
The e400 spec sheet is on the Cambium website under 'Spec Sheets' near the end of the page here:
https://www.cambiumnetworks.com/products/wifi/cnpilot-indoor-wi-fi/
direct link:
https://3fdumf3rqw5xx4mjgywguwz9-wpengine.netdna-ssl.com/wp-content/uploads/2017/09/SS_cnPilot_e400_08102017.pdf
