we have several cnPilot E410, they are on 2,4 and 5 Ghz. Firmware is 3.9-r3. The E410 gets IP via DHCP (That works). There are two ssid´s. On one ssid the wlan clients get an IP Adress from the LAN DHCP Server on the other ssid they won´t.
The network looks like this:
Windows Server with DHCP Server <-> Switch <-> Cambium E410
This is what i did: reboot, reset configuration and reconfigured eyerything.
Thanks for reply.
