I´m testing a cnPilot E500 outdoor AP. It´s powered by the included Cambium POE, connected to a Netonix switch via cat 6 cable.
Problem is, that after a while, it looses connectivity at all. If I reboot it, the AP grabs an IP from my DHCP server (Mikrotik RB4011), responds 4 or 5 pings (from the same subnet) and then nothing. The green power LED is on, while the LAN led is orange.
This AP is associated to my cnMaestro on premises. If I factory reset it, it works ok for a while, I can claim it from my cnMaestro and provision it. After a few minutes, the behaviour reappears.
It´s on 4.2.1r12 firmware, and cnMaestro is 3.0.3r32
The strange thing, is, I have an e410 downstream from the e500, powered by the e500’s POE out, and it’s currently working perfectly, even with the e500 showing no connectivity.
Please tell me if I can provide more info.
EDIT: Connected a E502S to the same cnMaestro and did the same thing. It rebooted itself and loosed connectivity
EDIT 2: Disabling STP on the switch ports where the APs are connected, and rebooting them seems to solve the problem. Nothing on the logs. I will check again tomorrow and post an update.
