Hi Cambium Team,
I installed cnMaestro OVA 2.2.0-r60, updated via package to 2.2.1-r32
I want to add to created AP group APs with management vlan other than 1 (for example 403). At first I created vlan 403 on the AP with static IP address, changed Eth1 port to trunk mode with untagged 1 vlan and Allowed VLANs: 403, changed default route to GW for int vlan 403.
After that I try to add this AP to AP groupon cnMaestro. But in "Device Overrides" I see only 4 tabs: "Radio and Location", "cnMaestro VLAN (VLAN 1)", "Other VLANs", "WLANs". I do not see vlan 403 neither in cnMaestro VLAN nor in Other VLANs. I think it is not correct. If I add this AP to AP group , I can't access it via IP , not directly, not via cnMaestro. Could you tell me the right way to have management vlan other than number 1? Or it is a bug?
