Dear Cambium team,
How can we put cnPilot FW on ePMP1000 integrated ? With epmp 1000 connectorized we did not have issues but integrated radio refuse to upgrade. We would like to use it as outdoor hotspot and manage it with cnMaestro.
Thank you.
What version of software is on the unit.
You have to be at ver 2.4.3 (I think) before the upgrade works.
I upgraded to 2.5 and then it worked fine.
Did anyone try as suggested to get to version 2.4.3. I believe we had one failure, but it appears to have worked for most other folks, I ping'd internally. Looking for further feedback ...
