Hi, I revied the documentation for cnPilot but can't seem to find an answer. I'm looking to create 4 vlans on the LAN side only of the R201. I will trunk these through to a switch where they'll be delivered to a couple of E410 access points. Just hoping someone can confirm this setup is possible with the R201? It will be sitting behind a 300mbps connection to the internet serving 4 separate office spaces (only 1-2 persons per office). Thank you
Hi ,
R-Series doesn't support VLAN on LAN/SSID.
Regards,
Nilesh
