cnPiplot E500 wifi OUTDOOR AP
How many users can log in simultaneously and the distance of outdoor wi-fi range
The maximum number of concurrent users is 256. For most real world situations however, you'd probably not want to put more then 50 subscribers on this AP. This unit is rated for outdoor use and has a larger internal omni directional antenna and good 2.4 and 5GHz TX power. You should be able to get excellent range out of this AP for a festival, campground, or RV park. Obviously nearby obstructions and their material composition along with client signal strength will play a huge part in the range of this radio.
