When I open CNUT 4.0, I receive an error message that states
Failed to start HTTP Server: java.net.SocketException: Permission denied
If I click OK, the program seems to run without any problems. I’m running this on Ubuntu 10.10 64bit (I know it’s not officially supported but it has worked in the past). Any ideas what could be causing this?
What user are you running it as? Only root has permission to start a service listening to ports below 1024.
That said, I’m not sure what it even uses a local HTTP server for, unless some of the gear it can manage is directed to the CNUT-running machine to download its own updates via HTTP. (normally that kind of arrangement uses FTP or TFTP AFAIK)
That said, I'm not sure what it even uses a local HTTP server for, unless some of the gear it can manage is directed to the CNUT-running machine to download its own updates via HTTP. (normally that kind of arrangement uses FTP or TFTP AFAIK)
j
I've tried it as root and normal user.
I'm not that worried about it. As a matter of fact, given that I'm not sure why it's trying to do a HTTP server and what it's for, I prefer that it not be running (at least until I learn more about it).
