I will highly recommend for CNUT next generation to have multiple firmware upgrade options. Meaning that when you you upgrade the AP the brances or SM are upgrade at the same time. It is time consuming to try to make it one by one when you have 9 or 20, then the AP. Please, it's about making things easier
Thanks for your consideration.
