I am using 1.10, I am trying to update all my radios to 7.36 so I can move to CNUT 2.x to upload 8.1x. The issue that I have is this and it drives me NUTS. I add a new network element say AP, I then click on the refresh the network element and it will find Auto-detected SM’s. I look at the list and choose all the ones that are say 7.2.9 . I then go to Update manage packages and choose 7.3.6 and choose update selected network elements. I always get the following message:
08/23/07 16:32:02 INFO DeviceStatus=Status:-1;HOST:AP:[10.5.10.18].LUID:[020];ESN:0A003E92242A;Message:Unable to communicate with Network Element (Possibly Connect/Login Failure) ( SITE= Customer 01
SNMP settings are correct, evertyting, If I change the "Host Name on the Auto-Detected SM to the IP of that SM it works flawlessly each time.
I want to update my network without having to input each and every sm to upgrade them. I currently have 75+ access points and close to 5000 Sm’s?
J
Without the IP address of the SM, CNUT cannot directly update the SM. You should enable Autoupdate on the AP which will then update the SMs.
