cnWave 60GHz System Release 1.0.1 has been released. Find the firmware and full release notes at https://support.cambiumnetworks.com/files/60ghz-cnwave/
Problems corrected in official 1.0.1 since 1.0.1-beta6
Issue number | Products | Description |
60 GHz cnWave-2003 | All | 1G SFP link did not come up unless auto-negotiation on router/switch was turned off. After this fix, auto-negotitation should be used |
60 GHz cnWave-1900 | All | Upgrading nodes from onboard E2E UI in Safari browser did not work. |
60 GHz cnWave-1926 | All | Rebooting the cnWave device from the UI did not work occasionally. |
60 GHz cnWave-1942 | All | SNMPv2 did not work with IPv4 address. |
60 GHz cnWave-1980 | All | After software upgrade, the UI dashboard displayed Failed to fetch sector information error for a couple of minutes. |
60 GHz cnWave-2008 | All | Improved MCS 10,11, 12 performance. |
60 GHz cnWave-2035 | All | In V1000, packet loss is seen occasionally. |
60 GHz cnWave-2055 | All | Scheduled Beam Adjustment scan is supported. |
