cnWave 60GHz System Release 1.1 has been released. Find the firmware and full release notes at https://support.cambiumnetworks.com/files/60ghz-cnwave/
cnMaestro version 3.0.3 (or higher) is compatible with this release
Upgrade the External E2E controller first and then the nodes (where External E2E is used)
When using onboard controller, its recommended to upgrade the whole mesh together.
Features introduced in System Release 1.1
- VLAN
- DHCPv6 Relay
- Customized SLAAC CPE Prefix
- CN Backup link
- βDisable Unknown Unicast Floodβ configuration option
Problems corrected in System Release 1.1
Issue number | Products | Description |
60 GHz cnWave-1791 | All | When device was reconfigured to DN from PoP, BGP session was not brought down. |
60 GHz cnWave-1881 | All | Ethernet statistics displayed the link as up when the port was disabled in the configuration. |
60 GHz cnWave-2136 | All | When PoP was going down, the time taken to switch Layer2 tunnels to another PoP was optimized. |
60 GHz cnWave-2142 | All | When a BGP session was active for more than a day, the statistic details of the BGP disappeared. |
Known Issues or Limitations in System Release 1.1
60 GHz cnWave-1815 | All | Description : Occasionally, software image download from an external controller to the device takes 15 minutes. Workaround : None. |
