Hello,
We are deploying a site with multiple PTP setups and we are planning to use v3000 for each link i was wondering what is the minimum angle of separations that we need to have between the radios to minimize the interference.
20 degrees minimum separation should be safe. You can probably go less than that if you are careful with channel and golay planning, but 20 degrees should be good for same channel, different golay code for adjacent links. Also, make sure that the site that your v3000’s are co-located on all have the same polarity - either all even, or all odd - don’t mix them up, or you can have self interference.
