Who out there has Advantage and non-Advantage APs operating in the same cluster? What type of mix in the cluster do you have, for example 1 Advantage AP and 5 regular APs, etc?
When you installed this configuration you had to use the Frame Calculator feature of Release 6.1 to make sure that different frame structures of HW scheduling and SW scheduling did not interfere with each other. Did you find the instructions on this Frame Calculator (as describe in section 6.2, page 18-21 of the Release Notes) straight forward? If there was confusion, what tripped you up?
As Advantage APs continue to make it out into the field we are looking to make sure that our instructions are as easy to understand and use as possible.
Thanks.
