I need to install a BH10 on the same tower where a BH20 is currently located. Frequency separation should be possible, but I’d like to sync them to each other if possible to avoid any trouble.
I read Motorola’s recommendations for colocating BH’s (timing masters at the same site, synced with each other, same download percentage), but I didn’t see anything about locating BH10s with BH20s.
Does anybody have any experience with this? Should it work? Would I be better to not sync and just try to use separation?
-Tim
Yes, you can install them on the same tower however you will want to make sure they are in sync. To do this you will need a CMM to provide GPS timing for the two devices. As you stated there will need to be frequency separation for the two units.
I don't have a CMM at this site, but I should be able to generate sync from one master, and sync the other master with it, correct?
-Tim
That is correct. You can pass the timing from one master to the other.
What is the Frequency Separation Suggested between two co-located BHs in this Case…?
If you have a lot spectrum then the more the better but in a crowded environment then minimum 20 MHz.
