HI all,
I was looking for ePMP colorcode OID in following list but didn't found any did cambium removed it ???? then what i can use instead of that ?????
please help,
thanks.
Bilal
HI all,
please help,
thanks.
Bilal
I just had a look in the MIB for ePMP 2.5.1 and I can't see an OID for colour code either. Was it in a version previous to 2.3.1, do you know?
Alex
hi alex ,
I really don't know about older versions of MIB, but PMP MIB files have color codr OID.
Please share if you find it.
As far as I recall, ePMP has never had a color code feature, though other Cambium PMP product lines do. Without support for colorcode, I'd never expect to find a useless colorcode OID...
j
You are correct, ePMP doesn't support colour codes, hence no OID.
