Hi there
Is there any generic information available on commissioning and acceptance of PTP820 links.
Avinesh
Hi there
Avinesh
@Avinesh wrote:Hi there
Avinesh
What do you mean by that? Are you trying to buy a license for a specific band in your country for PTP820?
Hi Eric
I am not inquiring about the license. I was seeking information on whether there is any available information or if someone would like to share regarding field acceptance test. Basically what parameters can be tested to confirm the link installed in of acceptable level/standard
Cheers
I'd design the link in Cambium's free too, LinkPlanner... this will give you an excellent idea of what sort of signal levels, modulation rates, throughput, and % uptimes that you can then use to compare (or build out) a PtP.
Avinish,
Feel free to contact me via email.
You should have my card from Melbourne.
Brook
