Hello,
do the cn reach N500 compatible with IEC 60870-5-104 protocol.
thanks
Hello,
thanks
Hi Mohamed,
cnReach doesn't natively support (generate or terminate) this IEC protocol which is used for electric utility substation communications.
However, cnReach will pass these protocols transparently as layer 2 traffic as long as the link quality and modulation achieves the desired capacity of the application (throughput and latency).
Regards, Bruce
