Is there a way to connect through cnMaestro to a Force 180 acting as a PTP link which is connected to a R190 router’s LAN port ?
Hi Udithas,
When you say connect through cnMaestro , do you want to manage the R190V and the PTP 180 link through cnMaestro server . If that is the case if the Router and the Force 180 devices can reach the cnMaestro On premises or Cloud servers then we can definitely manage them through cnMaestro . But launching the Force 180 device GUI from cnMaestro will not work as the devices will be having NATted addresses as they are connected to LAN ports of R190V.
KR.
