Hi All
Just after some advice (this is the first Ubiquity device I've used).
I am unable to connect to the Web Front end using the default username and password. I'm able to connect via Putty to the CLI and change the admin password but that makes no difference. HTTP and HTTPS management is available.
Software version is 1.61-r3
Im also not having any joy with applying the softare update via TFTP........
Any suggestions would be greatly welcomed,
Markos
