Hello,
I’m trying to configur HW Scheduling on one AP but I didn’t see any option in the configuration page of the AP. Wich steps I must follow in order to configure the AP and the SM that are conected.
The AP share the tower with two BH (both with release 7.3.6 and runing HW Scheduling)
I’m having some problem with the link in the AP and I read that colocated BH should operate with HW Scheduling under the release 7.3.6
I appreciate any sugestion.
jgonzalez wrote: Hello,
I'm trying to configur HW Scheduling on one AP but I didn't see any option in the configuration page of the AP. Wich steps I must follow in order to configure the AP and the SM that are conected.
I'm having some problem with the link in the AP and I read that colocated BH should operate with HW Scheduling under the release 7.3.6
upgrade to latest firmware 7.3.6 and telnet to your AP and type "ver", see the board version, if there is not P9, and then you must change your AP to AP with P9 board
regards,
mrdlnf
Thanks for the quick answer. Effectively the version of HW is P8. Now I have another question, most of the SM connected in my network are P8, so I think that I should keep SW Scheduling on the AP.
I have two BH module release 7.3.6 (P9) an one AP release 7.3.6 (P8) colocated in the same tower. According with the release notes I must configure both BH with HW Scheduling. The question is can I colocate both BH with HW Scheduling and the AP with SW Scheduling without having problems ?
The three modules are conected through a CMM for sync.
jgonzalez wrote: Hi,
in release note said that only collocated BHMs running software scheduler under 7.2.9 or 7.3.9. So IMHO there is no problem. I have no experience collocated the BHMs with 7.2.9/7.3.6 because i use 7.1.4 in BHs :-)
regards,
mrdlnf
