A client wants a switch that supports IGMP.
I have never done it.
Can cnmatrix do IGMP and how is it configured
IGMP snooping is supported but you still need to know about that topic not just c/p commands.
Do you have some topology, example what customer needs?
cnMtrix supports IGMP snooping and proxy. IGMPv3 is not supported in the current release. One common mistake that inhibits IGMP snooping to work properly is the missing of an IGMP querier, which must be present for each vlan that multicast forwarding is required. cnMatrix can be configured to be an IGMP querier with a specified ip address to be used in the querier election.
