Connecting WIFI using company login credential
does anyone know if there is anyway to use our company login credential ( unique to individual ) instead of WPA2 PSK ? or other authentication method ( eg, using google authenticator)
Try NPS via Windows AD, it works as a RADIUS server on any WLAN you fix it. Other than that you can just create your own via ePSK, giving each end user a single username and password, you can even bind them to specific MAC ADDRESSs, adding an extra layer of security/privacy
