Correct Part codes in Link planner
When we create any BOM through link planner there are many part codes which are not correct ..can you fix the part codes in link planner.
Can you provide more details? As far as we know the BOM generated by the LINKPlanner is accurate and the correct parts are automatically inserted. The part numbers do not contain the part suffix (e.g. “C000065S011A” would be “C000065S011” in LINKPlanner). This is because a different version of the part may be available, but LINKPlanner will always use the description for the latest version.
