Does anybody know this bug?
The 5400 SM is configured with NAT+DHCP enabled.
The crash happens every time I issue the “arp -a” command via telnet.
00:00:00 UT : Mon Jan 01 2001 : File src/syslog.c : Line 997 System Reset Exception – Watchdog Reset
00:00:00 UT : Mon Jan 01 2001 : File src/root.c : Line 409 System Startup
00:00:00 UT : Mon Jan 01 2001 : File src/root.c : Line 414 Software Version : CANOPY 8.1.5 SM-DES
00:00:00 UT : Mon Jan 01 2001 : File src/root.c : Line 418 Software Boot Version : CANOPYBOOT 1.0
00:00:00 UT : Mon Jan 01 2001 : File src/root.c : Line 424 FPGA Version : 102606
00:00:00 UT : Mon Jan 01 2001 : File src/root.c : Line 428 FPGA Features : DES Sched
09:04:35 UT : Tue Oct 30 2007 : File src/syslog.c : Line 1099 Time set
09:06:55 UT : Tue Oct 30 2007 : File src/syslog.c : Line 1099 Time set
09:07:53 UT : Tue Oct 30 2007 : File ipstart.c : Line 292 Task 29: bad net ptr
09:07:53 UT : Tue Oct 30 2007 : File in_utils.c : Line 225 FatalError()
09:07:53 UT : Tue Oct 30 2007 : File src/stack_dump.c : Line 140
Stack Dump information:
Current context Task: TEL1
Current Stack: 4%
Max Stack: 27%
Task Stack Dump:
0x00714f94: 0x00008000 0x00714838 0x0074e894 0x00712568
0x00714fa4: 0x00000bff 0x0003001d 0x006c6630 0x00000000
0x00714fb4: 0x00000000 0x00000000 0x00000000 0x00000000
0x00714fc4: 0x00001d05 0x03200800 0x00000063 0x00007f05
0x00714fd4: 0x000019e7 0x00000001 0x00000000 0x00715564
0x00714fe4: 0x00000211 0x00000d10 0x54454c31 0x00000000
0x00714ff4: 0x00000000 0x00714f98 0x00000226 0x00002ffc
0x00715004: 0x0000001d 0x00000009 0x00000000 0x54454c31
0x00715014: 0x0000012e 0x00000000 0x00777342 0x0016599c
0x00715024: 0x002755bc 0x00715030 0x00047938 0x0014f780
0x00715034: 0x000000e1 0x0071505c 0x000950ac 0x0014ed18
0x00715044: 0x006abdfc 0x00000004 0x00000006 0x006abda4
0x00715054: 0x00093998 0x00105578 0x00000042 0x00000041
0x00715064: 0x00000043 0x0000004b 0x00000003 0x0016522c
0x00715074: 0x00000000 0x00000251 0x00000256 0x006abbbc
0x00715084: 0x0000001f 0x00000006 0x006abfa4 0x0000004c
0x00715094: 0x00000050 0x0016522c 0x007150a4 0x00105750
0x007150a4: 0x00000002 0x007150d4 0x00000000 0x54454c31
0x007150b4: 0x002755c1 0x00000061 0x007150c4 0x00103820
0x007150c4: 0x002755bc 0x001cb4f8 0x00000002 0x00000001
0x007150d4: 0x002755bc 0x002755c0 0x00000000 0x00000000
0x007150e4: 0x00000000 0x00000000 0x00000000 0x00000000
0x007150f4: 0x00000000 0x00000000 0x00000000 0x002755c2
0x00715104: 0x00000003 0x000b4680 0x001b6a44 0x000bb344
0x00715114: 0x00000000 0x00000000 0x00000000 0x00000000
0x00715124: 0x001b6a44 0x00000006 0x006abdc4 0x006abda4
0x00715134: 0x00000000 0x000bb620 0x00000006 0x00000000
0x00715144: 0x00000000 0x006abde0 0x006abda4 0x000bb8fc
0x00715154: 0x00000000 0x00000000 0x00000000 0x00000000
0x00715164: 0x00000000 0x00000000 0x00000000 0x00000000
0x00715174: 0x00000000 0x00000000 0x00000000 0x00000000
0x00715184: 0x00000000 0x00000000 0x00000000 0x00000000
0x00715194: 0x00000000 0x00000000 0x00000000 0x00000000
0x007151a4: 0x00000000 0x00000000 0x00000000 0x00000000
0x007151b4: 0x000c5d40 0x00000000 0x00000000 0x00000000
0x007151c4: 0x00000000 0x00000000 0x00000000 0x00000000
0x007151d4: 0x00000000 0x00000000 0x00000000 0x00000000
0x007151e4: 0x000c5d58 0x00000000
Return Addr: 0x0010a10c
