The Windows is 32bits SP 1, I'm installing the Wireless Manager 4.5.6 (WMInstaller-4.5.6-windows-x86-installer) and I installed the last version of Java ().
I don't have any other SQL or CNUT or CNS server runing on this computer, it's a new windows server installation without anything.
The WM was installed sucessfull, without any error, but the MySQL database wasn't created.
Sorry, the Java was out of date and I update it and the database was created. Now I've the database called wmsdb and I put all informations on the WM administrator tool and click on Test button and everthing is OK, than I clicked on Apply button but nothing happening and If I try to get out the software or change to another option I receive the message: "Do you want to apply unsaved configuration?"
The software don't save the configurations that I typed.
