Has anyone used the Clyclone 900Mhz H-Pol 9.2dBi Omni antenna?
I’m considering using one in a location where sectors would not be useful.
If you have, how did it perform?
-Wayne
Well I took a chance and ordered one, I’ll guess i’ll be the guinea pig and test it.
I’ll try to get back on here and let everyone know how well it works or doesn’t work.
We’ve been using them for 5 years now. Work very well. Never had a problem with the antenna it’s self.
Awesome! that gives me a bit more hope.
Do you have any issues with snow/ice buildup on them because the elements are exposed?
What about installing them near (within 8 miles) a cluster of 6 60° APs? Has anyone tried this at all?
If that cluster is on horizontal. Path calculations put it at a -66dB on the receive side if the two have good line of sight between each other. That would give you a noise floor at the AP of about -63dB. Personally I would use a syncpipe and coordinate settings, or stick with a vertical omni.
I have towers within .5 miles of a 6 pack, with gps sync i have no issues to speak of, unless the other tower is coming in higher than my signal.
