Excuse the ignorance, but could someone explain daylight saving and its effect/use?
bump
chrisopq,
I don’t think you guys have daylight savings time over there in Africa. I could be wrong but since you ask, and because I always thought it was a USA / Europe thing, I assume you don’t.
We set our clocks back an hour each year in the fall season and then them (back to standard time) an hour forward each spring. Usually settings in computer equipment is just so your computer (radio or whatever) knows if it should set it’s time back an hour / forward an hour at the appropriate times of the year.
More info if here : http://webexhibits.org/daylightsaving/
If your country does not set your time forward or backward at different times of the year then it does not apply to you.
chrisopq wrote: bump
