Delete device offline cnmaestro
Hi team,
I’m currently experiencing an issue when trying to delete a Subscriber Module (SM) from cnMaestro. The device shows as offline, and when I attempt to delete it, I receive the following error:
“Unable to delete device since On-Prem instance is offline.”
The On-Prem server is currently online, and other operations in cnMaestro are functioning normally. Could this be a sync issue or something related to the device’s offline status?
Is there a workaround to force the deletion of offline devices in this situation?
Thanks in advance for your support.
Hi @cowper ,
Please verify the connectivity of your Anchor account, and once On-Prem is connected to Anchor, try performing the delete operation.
Hello Good afternoon, I would like to inform you that it is connected to the cloud.
Hi @cowper ,
This needs to be investigated, could you please report a support ticket.
This topic was automatically closed 90 days after the last reply. New replies are no longer allowed.
