Muy bueno dias, acudo a su experiencia para mejorar mi enlace para ello les informo como lo tengo
para esto les tengo unas antenas ALGCOM UHP 30 DBI
Agradezco su colaboracion:
Hello @HOWART_COFT_QUEJADA,
did you try Link Planner tool first to see what theoretically can be expected with your installation?
no caballero aun no la manejo
I suggest you to open a support ticket. Our engineer will be able to talk to you in Spanish and explain you about alignment and noise issues. There are many options to try to get your link improved.
Submit a request button win the top right corner.
https://support.cambiumnetworks.com/
