Design issue OSPF_eth interface-Radio-Vlan_Management
Hi.
I need your thoughts about this issue.
As depicted in the attached diagram, Im hesitating about having a mkt port with a ip configured on it and also a management vlan
through the same port, is this common? or I should run OSPF over another vlan and leave the ETH port with no IP configured?
Thank you guys.
