Device Dashboard Show Management VLAN IP
It would be helpful to show what IP the management interface has  on the dashboard. The public IP is there now and is quite helpful but won't assist support folks from logging into the device if needed.
We are planning to provide a hyperlink for public IP Address so that clicking on it, cnMaestro opens device UI in separate browser window/tab. Would this suffice?
That would be nice, but not really what I am asking. If your management IP is on a private VLAN (perhaps shared with the voice vlan) then it will not be the same as your public IP issued to the router. In that case 2 separate IPs would need to be displayed otherwise support people would not be able to easily find the private IP address of the endpoint. It was just a thought as I was playing with template creation.
