Device Name and special characters allowed?
Hello,
I've tried to rename a device twice and each time it goes into this 192.168.0.2 state.
I'm trying to name the antenna 411_Sailfish_BH(InterCoastal) and for some reason it no longer grabs DHCP.
How do I get it back out without manually resetting the antenna?
I see the antenna connected to the AP with the 192 address, can I telnet into it?
It was working fine until I renamed it, then it connects, but doesn't grab an IP.
Any thoughts?
I know if I go down there and reset it and give it another name it will work fine.
I have 5 other CPE's connected and they are also working fine.
Any suggesions would be appreciated.
_ is not an acetable hostname charater. you can use a - rather than a _   ( i don't remeber the RFC document) but they follow the same rules with the system name becuase its used at the Device hostname in the DHCP/DNS entries
