I have a 2.4 advantage ap and a 2.4 advantage sm.
The SM has high priority turned on and the diffserv’s are setup to defaults in each unit.
Sipura ATA settings
SIP ToS/DiffServ Value:0x30
RTP ToS/DiffServ Value:0x38
SIP CoS Value:3
RTP CoS Value:6
If I am doing things correctly
0x30 is code point: 48
0x38 is code point: 56
These should be high priority in the sm with default config?
This is located in the uplink stats
Shouldnt there be a listing for the code points? if they are being used?
Or am I mis understanding?
VC: 064 : CoS: 00
Queue Overflow Cnt : 392
inoctets Cnt : 0
inucastpkts Cnt : 618852
innucastpkts Cnt : 0
indiscards Cnt : 0
inerrors Cnt : 0
outoctets Cnt : 407492810
outucastpkts Cnt : 572676
outnucastpkts Cnt : 107
outdiscards Cnt : 392
outerrors Cnt : 0
Use packetyzer or other sniffer to capture some packets from the Sipura and make sure it is tagging the packets properly. The Diffserv field consists of 8 bits the first 6 are the code point and the last 2 are not used. If I remember correctly I had to add in the last two bits to get the Sipura to tag them properly, but that was a year ago.
I did figure this out with supports help
If you want to check and make sure you are using high priority on Hardware platform
Lookin in either the uplinkstats of the sm or the downlink stats of the ap
You should see somthing like this if HPQ is setup correctly
VC: 039 : CoS: 00
Queue Overflow Cnt : 144
inoctets Cnt : 0
inucastpkts Cnt : 225960
indiscards Cnt : 0
inerrors Cnt : 0
outoctets Cnt : 55104524
outucastpkts Cnt : 10293
outnucastpkts Cnt : 70
outdiscards Cnt : 144
outerrors Cnt : 0
VC: 255 : CoS: 01
Queue Overflow Cnt : 0
inoctets Cnt : 0
inucastpkts Cnt : 8
indiscards Cnt : 0
inerrors Cnt : 0
outoctets Cnt : 48371167
outucastpkts Cnt : 216404
outnucastpkts Cnt : 0
outdiscards Cnt : 0
outerrors Cnt : 0
