Hi, how to can you disable " Reset Via Power Sequence" via CLI? Thanks.
I've done it from linux monitoring server via snmp:
snmpset -v2c -ccommunity 10.12.12.3 .1.3.6.1.4.1.17713.21.3.6.1.15.0 i 0
snmpset -v2c -ccommunity 10.12.12.3 .1.3.6.1.4.1.17713.21.4.4.0 i 1
(first disables the feature, second applies changes)
I've also done it via cnMaestro with this template:
"device_props": {
"powerSequenceFactoryDefault": "0"
You can use the SNMP approach from the CLI of the radio itself though the syntax may differ.
j
Thanks. I'm gonna try it
