Disconnect for short 2/3 minutes.
anything conductive. you will be grounding it to earth.
why dont you just make a female to male jumper cable and run a temp dish in a different locaction? it would be 30 min worth of work and would probably solve your problem.
you can mount a temp unit on a umbrella stand for an outside table…or a pallet
The Entire Terrace in most directions have diffrrent kind of GSM Antanne installed & we tried moving the equipement to many locations onthe same terrace , but same problem of disconnect is taking place.Hence the shileding will have to be done.Or move from this property & find entirely differrent location.
Link Brack Every Aprox 1 Hrs… What Can I do ?
Pls Help Me on this…
Speed Test
Stats for LUID: 2 Test Duration: 2 Pkt Length: 1522
Downlink RATE: 3133440 bps
Uplink RATE: 3090432 bps
Aggregate RATE: 6223872 bps
Pkt Xmt (Act/Exp): 510/0
Pkt Rcv (Act/Exp): 495/0
Downlink Efficiency: 95 Percent
Downlink Index (Act/Max): 95/100
Frag Count (Act/Exp): 12785/12240
Uplink Efficiency: 94 Percent
Uplink Index (Act/Max): 94/100
Frag Count (Act/Exp): 12768/12072
Most Recent Registration Failure List
MAC : 0a-00-3e-23-d2-de BH ReRange 23:14:25 UT (01/01/01) Flag : 18351
MAC : 0a-00-3e-23-d2-de BH ReRange 22:16:01 UT (01/01/01) Flag : 18352
MAC : 0a-00-3e-23-d2-de BH ReRange 21:05:39 UT (01/01/01) Flag : 18350
MAC : 0a-00-3e-23-d2-de BH ReRange 21:03:03 UT (01/01/01) Flag : 18351
MAC : 0a-00-3e-23-d2-de BH ReRange 19:37:15 UT (01/01/01) Flag : 18351
MAC : 0a-00-3e-23-d2-de BH ReRange 19:36:41 UT (01/01/01) Flag : 18351
MAC : 0a-00-3e-23-d2-de BH ReRange 19:36:18 UT (01/01/01) Flag : 18351
MAC : 0a-00-3e-23-d2-de BH ReRange 18:54:13 UT (01/01/01) Flag : 18351
Session Status List
LUID: 002 : MAC: XX-XX-XX-XX-XX-XX State: IN SESSION (Encrypt Active)
Site Name : XXXXX.
Software Version : CANOPY 8.1.5.1
FPGA Version : 041006 (DES Sched) P9
Session Timeout: 30, AirDelay 1861 (approximately 17.27 miles (91189 feet))
Session Count: 15, Reg Count 14, Re-Reg Count 7
RSSI (Avg/Last): 1152/1181 Jitter (Avg/Last): 6/7 Power Level (Avg/Last): -59/-58
Low Priority Uplink CIR (SM): 0 (kbps) Low Priority Downlink CIR (SM): 0 (kbps)
Rate : VC 18 Rate 1X/1X VC 255 Rate 1X/1X
Radio Frequency Carrier : 2445.0
No hijacking threads dude…
