MaxDin
(MaxDin)
November 11, 2023, 8:24am
1
Best regards.
I have several PTP link with Force 300CSM and 300-25. After switching from TDD PTP to ePTP mode have daily issue with trop link.
LOG on SM:
F=5140 11acvht40plus. Reason: 51 (AP INITIATED DISCONNECT)
LOG on AP:
aid=1 disassociated. Reason: 53 (AP KEEP ALIVE RX STUCK)
ninedd
(ninedd)
November 11, 2023, 10:19pm
2
What version of the firmware are you using?
MaxDin
(MaxDin)
November 13, 2023, 2:59pm
3
Software Version = 4.7.0.1
ninedd
(ninedd)
November 13, 2023, 5:37pm
4
MaxDin:
Version = 4.7.0.1
4.7.0.1 has known disconnection issues. Might not be the issue that you’re running into, but then again, it might be just that simple as well.
If you’re on 4.7.0.1 then I would say to either downgrade to 4.6.2, or better yet upgrade to 4.7.1-RC21
Cambium has said that RC21 will become the official 4.7.1 Release Version unless there are new issues reported (ie, all other known issues have been solved & squashed in RC21) so it is a mature and stable release candidate… which likely IS actually the 4.7.1 Release Version… we’ve been running it on about 400 radios with no known issues.
You can find the 4.7.1-RC21 beta https://support.cambiumnetworks.com/files/epmp3000/beta or in cnMaestro Cloud.
MaxDin
(MaxDin)
November 21, 2023, 8:27am
6
We still have the connection drop problem, Software Version 4.7.1-RC21.
Log on AP:
kernel: [83660.041391] SM[bc:e6:7c:XX:XX:XX] aid=1 associated with AP
Oct 17 10:03:19 F300 kernel: [83461.661278] SM[bc:e6:7c:XX:XX:XX] aid=1 disassociated. Reason: 53 (AP KEEP ALIVE RX STUCK)
Oct 16 11:53:08 F300 creporterd: kernel process_crash... get_crash_data fail : -1
Oct 16 11:33:08 F300 creporterd: kernel process_crash... get_crash_data fail : -1
Oct 16 11:13:08 F300 creporterd: kernel process_crash... get_crash_data fail : -1
Oct 16 10:55:39 F300 kernel: [ 201.533347] SM[bc:e6:7c:XX:XX:XX] aid=1 associated with AP
Oct 16 10:53:06 F300 snmpd[2740]: DFS status: N/A
Oct 16 10:52:59 F300 snmpd[2740]: DFS status: Error!
Log on ST:
Oct 16 11:45:50 F300-ST creporterd: kernel process_crash... get_crash_data fail : -1
Oct 16 11:25:50 F300-ST creporterd: kernel process_crash... get_crash_data fail : -1
Oct 16 11:05:50 F300-ST creporterd: kernel process_crash... get_crash_data fail : -1
Oct 16 10:53:13 F300-ST kernel: [ 555.590000] SM associated with AP[00:04:56:XX:XX:XX]
Oct 16 10:49:52 F300-ST kernel: [ 355.360000] SM disassociated from AP[00:04:56:XX:XX:XX] F=5140 11acvht40plus. Reason: 34 (BEACONs MISS)
Oct 16 10:47:48 F300-ST kernel: [ 230.690000] SM associated with AP[00:04:56:XX:XX:XX]
Oct 16 10:45:50 F300-ST creporterd: kernel process_crash... get_crash_data fail : -1
Oct 16 10:45:13 F300-ST snmpd[2578]: DFS status: N/A
Oct 16 10:45:10 F300-ST mount_root: no jffs2 marker found
