Chaning the Mode in Map view doesn't update the APs on the map. For example, if I change the mode to "Registration Count" it continues to show the defaut device up/down status. If I click on an AP and look at the SMs that are connected, they will show the registration count, which is of course zero for all of them.
Is it the cnMaetsro cloud based application you are looking at?
Could you please share the screenshot of the issue you are having?
Regards,
Mahip
On-premise 1.2.2-r3
Notice that the icons for the APs don't show registration count, as I assume they should.
If I click on an AP it shows "Resistration Count" on the SM icons.
