Does anyone know if the N009045D001A (900 Mhz 450i sector) has electrical downtilt? - Thanks
The plot on the spec sheet shows zero downtilt, also seems to show no null fill.  Vertical beam is pretty wide though, 23 degrees.
You can see the pattern data on the spec sheet here.
There is no electrical downtilt built into the antenna. The sliding bracket at the top allows for a significant mechanical downtilt, as seen in the picture below.
appreciated - thanks for the quick reply
