Does the standard hardware included with the ePMP Force 180 support mounting it directly to a wall? Any documentation or instructions on mounting it to a wall? I see the pole mounting option. I thought I had seen where it gave you the hardware for either pole or wall mount.
We use a fair amount of these for wall/fascia mounts (also at baltic) Liard Wall Mount
And this Tycon heavy duty wall mount we have even mounted F200's on though we usually drill 2 extra holes and put couple extra screws at the sides when putting a F200 on them.
There was some mounts we use to buy off Ebay from a Zirkel but they stopped selling them a couple of years ago. I would love to find a new source for them they were awesome ( I still have a few that I only use when no other mount will do the trick)
