I accidentally upgrade a couple of BHs (P8) to the release 7.3.6 the problem is that the P8 plattform don’t support hardware scheduling. The questions is witch steps should I follow to downgrade this modules.
The modules are colocated with P9 BH release 7.3.6 using hw scheduling.
Use CNUT, same as update.
There are no risk if I use CNUT to downgrade this modules to release 7.1 ?, Should I follow the same squence, first downgrade to 7.2.9 and then to 7.1 ?
I have downgraded about 50 BHs directly to 7.1.4, no mater wich software they were having. There were no problems.
