Looking at the spec sheet i notice it says the sector antenna is 90 ~ 120 degrees. What does that mean exactly? Currently I have 25 E 501 APs deployed in an RV park. I only have half turned on becuase I believe they were interfering with each other. I want to try a more narrow sector antenna to see if it helps with the interference as the problem is still ongoing. Any ideas?
Does anyone have a spec sheet for the E501 Aps?
Hi JBrantley,
Please find the link to download E501S datasheet
https://www.cambiumnetworks.com/products/wifi/cnpilot-e501s-wifi-access-point/
90-120 is the coverage angle.
For more narrower sector option you can take a look at our E502S sector antenna AP, which has 3o degree sector coverage. Datasheet can be downloaded from the below link
https://www.cambiumnetworks.com/products/wifi/cnpilot-e502s-wifi-access-point/
Regards
Anand
