For all the e3K users out there, what firmware are you running? Have you gone beyond 4.8?
I have a very stable 4.8.1 expression. No problem.
We run 5.10.4 on all of our e3k radios.
@Eric_Ozrelic @ahteran thank you both for your replies. @Eric_Ozrelic does the asymmetric setting work on the e3k on 5.10.4?
If you’re running a 4500 AP in compatibility mode with AC clients, then yes, it’s supported. Asymmetric use is not supported on e3k AP’s.
Thank you for your reply!
