E500 PoE-Out, what can power?
The PoE-Out port of a E500 can power a Ubiquiti M5-400? (in the spec sheet the power supply says 24V, 0.5A).
With setting on PoE-Out "Cambium PoE" the Ubiquiti power up
We need to use a e500 with a PowerBeam M5-400 because where the PMP450 SM is installed there's no line of sight se we used a Ubiquiti radio bridge.
Thanks!
hi,
e500 supports 2 power modes on ethernet 2 port,
1. cambium mode to power on cambium back haul device and
2. 802.3af mode to power on poe devices
if ubiquity ap works with 802.3af standrd we can power on.
for this use case plz make ensure that e500 ap is powered on using cambium supplied power adopter 56v/30w unit
