e505 dimensions?
Hey, fellowes :)
To anyone has e505 AP on hand, could you measure it's dimensions? I believe that's data sheet specs isn't correct for this one.
If you'll also post some pictures with a ruler, it'll be much appreciated.
Thanks!
hi,
measured data 225x130x68 mm. spec correction will be considered.
