Hi all, so I have a e600 and I do not understand why the RF quality on both 2.4 and 5 are poor… did a scan and both channels are clean… the 5ghz is ridiculously clean
Try setting the channels to 1 and 36.
Hi, thank you for your reply! I will try but can I inquire why?
As I am in the US… I always start with the best practices in wifi based on my region.
Can you please share me the following information to understand whether it is a display issue or real RF quality issue
- Are you facing any connectivity issues
- Is clients are able to scan the SSID’s ?
- What is the firmware version that you are using on the APs?
Using the latest firmware… house is only 1000 sq ft, very poor throughput near or away from the AP… put in $70 TP link router in AP mode and its out perform the e600… ouch…
Check your channels turn off auto channel, make sure 5ghz radio is not using 80mhz wide channel, turn 2.4 ghz on to 40mhz wide channel. Set 2.4 to only use channel 1,6 or 11.
There are other tweaks too but start there and test.
