Has anyone tried using the mesh feature with only e700s?
We've tried at two different locations and changed in both instances to using an e700 base with e500 mesh clients. The client e700s would drop from the mesh and not reconnect nor connect to the recovery ssid. After attempting to replicate in our office, we can't get the client e700s to drop, though we get less packet loss and lower latency to the e500 clients vs the e700 clients.
We are having seriuos porblems with the mesh on our first E700 deployment. The mesh will run fine for a random period of time and then drop. Once the mesh drops, the network is essentially unusuable.
The mesh works. I will say you get less packet loss using an e700 mesh base with e500 clients. Cambium was helpful, while not following up in this thread we had a dialog via email.
Performance is good for us, but we can rarely provide over 20Mb to our locations We use it outside to connect different facilities at a drilling rig. Not having to run cables in an environment where they are easily damaged has been a big plus and we intend to roll this out to all drilling locations.
Can you please elaborate what is the issue that you are facing with mesh ?
What is the firmware version running on these devices ?
can you please share us the below requested information which will be helpful in understanding the issue
How AP’s are deployed ?
What is the RSSI between Mesh Base and client ?
Distance between mesh base and mesh client
If possible can you please share me techsupport files of mesh base and mesh client AP’s on email id ashok.kumar@cambiumnetworks.com
