Hi Everyone,
I am having a very strange problem with Prizm. I installed Prizm a few days back and everything has been working well, I used postgresql as the dbase.
I got a call from my boys two days ago and he told me that discovered elements don’t move to the managed elements window even after Prizm confirms that it was successfully moved. This was working before but just started happening. It’s impossible to move new discovered elements to managed elements - I have checked the forums and have no clue why this is occuring.
I will appreciate all the help that I can get.
Alex
I found out what was wrong, prizm was installed on the root partition (/), and the root partition was allocated 1GB of space, so prizm or the dbase couldn’t write more data because the partition was full.
I mounted the /var/ on a new partition, and everything worked well.
Thanks.
