When i elevate some SXT Lite5 i've recie this message in log and wireless not work.
kernel: split_squashfs: no squashfs found in "ar934x-nfc"
I can see that the tx power transmit state is off.
Regards
Regards
The issue should be fixed in the latest 4.5.4-RC7 Beta.
Could you please give it a try?
Thank you.
Tenia el mismo inconveniente con los equipos Mikrotik elevados, pero con la version 4.4.3 es mas estable. Saludos
